Stock suspension?
You don't really need any suspension mods for a stock car.
Torque box reinforcements help prevent the brackets that hold the rear control arms to the body. The spot welds can potentially deteriorate... but without significant power/aftermarket control arm bushings you will be fine.
Sub frames tie the front and rear frame together and reduce body flexing.
even on a stock car, subframe connectors show a significant increas in the stiffness of the body,
And i have seen a hatch that had a basically stock engine on a really sticky tire start to tear a box... Once a box is torn, it can be very expensive to fix
and the stock suspension makes a mustang look like a 4X4
09-08-2015 11:50 AM
