Cams
Old Apr 26, 2010 | 08:36 AM
83gtdroptop's Avatar
83gtdroptop
Default Cams
ive got a question...i just bought a 83 gt conv. 5 speed 5.0l carb....what kinda of cam should i get and would i need to buy heads also?
Old Apr 26, 2010 | 01:15 PM
83gtragtop's Avatar
83gtragtop
Interesting name. The stock cam is all you need if you still have stock heads. You will not see much if any performance gain with a cam swap.
Old Apr 26, 2010 | 01:31 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
I thought it was you at first rag! lol
Just a cam swap for performance is pointless. Most people don't know any better and swap a cam that sounds good and think that it will get them more HP
Old Apr 26, 2010 | 06:22 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
COMP XR292 solid roller...
Old Apr 26, 2010 | 09:38 PM
83gtragtop's Avatar
83gtragtop
Haha, so did I. "When did I post this?"
Glad there is another '83 GT Vert on the site. There are much less than the 1001 originally produced still on the road.
Old Apr 28, 2010 | 09:36 AM
83gtdroptop
ok with the whole cam vs heads thing...im looking to do one or the other regardless but what should i do first...and what would i need like if i got a cam ...would i need the whole shabam like lifter rods etc.on the stock heads or should i get some new heads ?or should i just go heads then cam? any ideas?!>!>?!?!?
Old Apr 28, 2010 | 12:28 PM
w8less's Avatar
w8less
i would do heads and then cam. you will see a bigger gain with better flowing cylinder heads
Old Apr 28, 2010 | 12:38 PM
g3mustang's Avatar
g3mustang
i would do it all at once why go through all that work twice
Old Apr 30, 2010 | 01:28 PM
Venomantidote95's Avatar
Venomantidote95
it is true about swapping heads first, u can swap a camshaft first too though, if you want sound and just gonna use the stock heads. the stock e7 flow a whopping 151cfm at just under a .500 lift. if you can get somthing around that lift with a little more duration you can acheive a bit more power, granted you upgrade ur exaust ( headers aftermarket pipe and mufflers) which i think it the first thing i always do before the engine mods. after that if you do the cam and stock heads might consider feeding the cam with an intake, anything over stock but stay around an idle too 5500 intake band.
if and only if you are gonna do more than that like hci or more cubes etc, then you want to consider a wide range of things!! that can be explained later if you decide too.
keep in mind to each his own, its ur money and ur decision!!
good luck with your choices!
Old Apr 30, 2010 | 05:08 PM
83gtragtop's Avatar
83gtragtop
Get the heads first. The cam should be the last thing you get because the cam should designed around the parts you have.
