Blown head gaskets
Blown head gaskets
Ok heres the deal i have a 1998 mustang converted from v6 to 5.0 around 3 years ago. last summer i added a trickflow topend kit, with a professional products 70mm tb, 30lb injectors, ford racing lifters, c&l 76 cold air tuned for 30lb injectors, and flow tech headers. And have had nothing but problems every since it wont idle i think thats because of the fuel pump it still has the sixer pump but i ordered a ford gt pump for it the next day blew a head gasket 2nd one i dont understand why it keeps blowing them. I have read that the 5.0 blocks are poorly made and the decks warp could this be it. Im out of ideas can anyone help?
Yes i followed the torque with trickflow kit and I put rtv as directed ok i forgot to mention this and i know it was stupid i know the first time it blew was i had a bum torque wrench and it was my first time doing a topend so the wrench didnt click after 65lbs so i pulled until i heard it and i heard a click more like a pow i snapped the head bolt in the block well i had forgotten to put rtv the first time and my uncle who has been working on muscle cars for years and i dont know if its different for old cars from the 60s but he reuses head bolts i told him you shouldnt but i took his word he had never had any problems so i used the old head bolts i think that is why it happened the first time. Now the past time i changed gaskets i bought new head bolts but i used factory replacement but i put the rtv sealer on it and i followed the torque seq. and specs. could the factory head bolts cause it to blow this time?
Molys? i checked the heads last time the were straight i didnt check the block. heres what it done i havent pulled the heads yet but i got off the interstate and it was blowing white smoke pretty bad. i pulled in the driveway and it was really smoking. so i cut it off to check the oil for anti freeze i didnt see any but when i went to start it it wouldnt crank like the cylinders were full of antifreeze so i left it i didnt want to bend a rod. my dad started it the next day it smoked bad we have a garage so i drove it 15miles to the garage and the car started missing i mean i could feel almost every stroke it made. it looked like something you would see off nascar as i went through town i parked it cause on the way up it start heating up it never went red but it wasnt far from it.
no i didnt but i will this time also i was adjusting the valves and where the intake goes over the valve cover i had to take it off to get the valve covers off i was putting the intake back on after adjusting them i guess where the motor got hot when i tightened the front bolt on the pass side it cracked right behine the bolt put not all the through could that cause a vacuum leak and effect the idle? will the new fuel pump help idle issues? thanks so much for your help
Ok so I was wondering if my block could be warped? I have heard that these block are said to be poorly made I was just wondering if that could be causing it to blow headgaskets could the deck be wavey answer will be greatly appreciated.
