my build...opinions?
Old 06-02-2010, 02:34 PM
ProTrickVic
ProTrickVic's Avatar
Default my build...opinions?
hi everyone! first post here. been lurkin in here for a while. just figured i'd try my luck at posting and seeing what this thing is capable of. i havent quite finished but shes close. just wondering what kind of power it'd put down and possibly how fast i'd be.
306
scat forged i beams ultra lights 5.4"
probe forged pistons about 300 grams standard flat tops with valve reliefs
cast 3" crank
solid billet roller cam
shaft mount rockers
approx .540/.560
190FAC heads milled down to ~50-52cc chamber with matching springs to cam
super victor intake
pro systems custom carb 780 carb
tko600 trans
8.8 rear 4.56 gears
275/60/15
thanks guys, let me know
ProTrickVic is offline
Old 06-02-2010, 02:35 PM
ProTrickVic
oh yea. its a 1991 coupe thats gutted. weighs about 3100 with driver
Old 06-02-2010, 03:35 PM
Slick68
Slick68's Avatar
She should be a nice little screamer. :O
Slick68 is offline
Old 06-02-2010, 03:49 PM
ProTrickVic
and what does that mean?
oh yea has 1 3/4 primary long tube 3" collector 3" straight pipe with flow through mufflers dumped at the trans. no cross over pipe.
Old 06-03-2010, 03:47 PM
ProTrickVic
sooo, no opinions?
Old 06-03-2010, 04:43 PM
tinman
tinman's Avatar
If you are going with a solid roller cam why are you staying so small?
650 lift is where they really start to come in.
IMHO, shaft mount rockers are sort of an excess with this combination.
If you are building this engine, make sure the pushrods are the right length and you are keeping at least .100 of valve to piston clearance......
tinman is offline
Old 06-03-2010, 04:52 PM
ProTrickVic
i must apologise i completely mis typed...sorry not very experienced typer....
~.640/.660 lift
hmmm, shaft mount for 8000rpms too much for the build?
really...
Old 06-03-2010, 05:13 PM
tinman
tinman's Avatar
I also think that a 650 D.P. carb is all that thing will really need.....
tinman is offline
Old 06-03-2010, 08:02 PM
68CSTANG
68CSTANG's Avatar
What block? Are you a member of SBFTech?
I ran 1 3/4" headers, and 3" straights to dumped chambered mufflers for two days and hated it..sounded like a truck IMO...I put in a balance pipe and it made it sound more like a Mustang again. But then again, the car didn't drone at all without a crossover so its a "give-and-take"
Everything with your build looks good to me. Who is grinding the camshaft?
Im not much for dyno's, but I don't see why a thought out combo like this wouldn't push over 430 at the flywheel. Tons of variables, but that would be my conservative guess. Post up some pics and Good luck!!
68CSTANG is offline
Old 06-04-2010, 09:23 AM
ProTrickVic
how did you calculate that?
iirc to calculate carb size its
cubes X RPM / 3456 X 1.1 = carb size
306 x 8000 / 3456 x 1.1 = 779.16
