Cams, opinion needed!
06-25-2010, 09:31 AM
I just bought the trick flow track heat 170 heads and was wondering what cams i should buy... All i have right now is headers, exhaust, h-pipe, CAI
06-25-2010, 09:52 AM
another question... how good is the heads?
06-25-2010, 11:54 AM
Banned
The heads and intake are both good. Grab a TFS1 cam and call it a day.
06-25-2010, 04:04 PM
Thanks umm what the difference/ pros cons on tfs1 and 2 cams. Also any links to exactly which one i should get
06-25-2010, 05:18 PM
Banned
The tfs2 has a bit more lift and duration to it. Which can lead to some PtV clearance issues. If you are comfortable with having your pistons notched, or have aftermarket pistons in the block already, then go for the TFS2. However, since I don't know you or your build, I'd still recommend the TFS1
06-25-2010, 05:41 PM
Thanks for the help... i think im gonna get the tfs1 because i dont feel like messing with the pistons
06-25-2010, 06:03 PM
So im getting the tfs1 cams and track flow track heat 170 heads...
How will
http://www.summitracing.com/parts/EDL-7123/ do with those heads and cams?
06-25-2010, 06:15 PM
Banned
why not get the Trickflow Track Heat intake?
There have been reports of the Edelbrock intake not lining up properly with the TFS heads... No idea if its true or not.
06-25-2010, 08:24 PM
D.R. THE PATHETIC DORK
Quote:
Originally Posted by
89MustangGT89
not tech so......
06-26-2010, 12:40 AM
sorry about that.. but idk ill see which one i choose because ive heard alot of good things from edelbrock
