lowering spring noises
So i installed Tokico blues all around and installed H&R sport springs.
stance is great but now when ever i travel over a bump there is a loud thump from the back.
could it be that the diff is hitting the stopper on the underbody?
Is it wise to trim these stoppers slightly to increase suspension travel?
Thanks.
Thanks.
I'm not sure if hitting the stopper would make alot of noise.
Go over your work. Make sure the shock absorber bolts are tight.
Before you trim any stoppers. Check the driveshaft clearance. If the stopper is trimmed, it may hit.
i double check all the bolts and they are good and i still have enough clearance re/ the tail pipes.
Thanks everyone.
Hey you have any before and after pics of your fox? I was reading your thread and looked up the H&R springs and the Tokico struts and shocks and it seems like a pretty good combo but seems like my front tire would rub if it was to be lowered another 1.5"?? Are you running the stock tire sizes on there right now?
the pic in my sig is stock unfortunately my camera is busted so no pics as of yet
tire size is 245/50/16 and yes im getting some rub issues up front.
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
