Help checking pushrod length
Old Jul 20, 2010 | 10:30 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
use a good set of rockers and such often doesn't occur, , clearance the rocker if all else is set up properly
Old Jul 20, 2010 | 11:44 PM
Lazor05's Avatar
Lazor05
Yeah Im guessing I should have spent a little more and just bought trickflow rockers as Im sure they are set up to work with trickflow heads.
Well heres another question. The roller is riding at about 2/5 up the valve and I have clearance with a 6.55 length pushrod. So not perfectly center. The instructions that came with the heads said that it doesnt have to be perfect, but the roller cannot move anymore than .8 on the valve surface. Well the tip travel is fine. SO question is, is the fact that it isnt centered perfectly going to hurt performance or durability? or both?
Im assuming that since it is not contacting right in the middle I will loose an extremely small amount of lift.
Old Jul 21, 2010 | 08:31 AM
ProTrickVic's Avatar
ProTrickVic
too low you can lose lift, too high you can break a stud off. get it centered. if you cant something is wrong with your geometry. should look something like this
Old Jul 21, 2010 | 08:53 AM
mjr46's Avatar
mjr46
I thought trick flow heads due to their design, most end up with around a 6.7 ish rod length, all the kits I have done came with a 6.7 ish rod length iirc.....
Old Jul 21, 2010 | 08:56 AM
ProTrickVic
yea, i've done two or three trick flow headed set ups. mostly around 6.7 ish. i did think it sounded a bit off that he has to be using 6.55....maybe didnt check himself enough?
if you're high on the valve lengthen your checker till your mark is did center and your sweep is tiny like the picture i posted. longer rod should move you down the stem a bit.
Old Jul 22, 2010 | 12:42 AM
Lazor05's Avatar
Lazor05
Yeah the paper that came with the heads said that a 6.750 pushrod is used, but the closest I can get the mark to center is with a 6.55. And thats with the mark being low (exhaust side of head) so I really need to go shorter! Could I have possibly gotten the wrong rockers?
Heres what I have.
http://www.summitracing.com/parts/PRO-66911/
When I recieved them there was a piece of paper inside the box that reference chevy rockers?! but then on the receipt ot said ford and the part numbers matched up with whats online. Im starting to think I have chevy rocker arms.
Old Jul 22, 2010 | 12:47 AM
Lazor05's Avatar
Lazor05
Well just went outside and checked and the packaging that the rockers are in says ford 302 1.6 aluminum rocker arms. So they are the right part. Im really confused.
Old Jul 22, 2010 | 07:05 AM
mjr46's Avatar
mjr46
it's not always about getting them centered, it's about getting the witness mark to be narrow.
Old Jul 22, 2010 | 08:17 AM
ProTrickVic
get them too low though and you'll start snappin studs off.
plz post a picture OP
Old Jul 22, 2010 | 08:53 AM
mjr46's Avatar
mjr46
I know what you mean, what I was getting at was an article written by Buddy Rawls. I'll have to see if I can find it
