Help checking pushrod length
Old Jul 17, 2010 | 06:24 PM
Lazor05's Avatar
Lazor05
Default Help checking pushrod length
So I am using an adjustable push rod length checker. Trickflow says I need a 6.75 rod. So I set it at that and tried it and it was a tad low. So I tried shortening the rod by .2 to 6.55 and it stayed in the same location?! Is this the lifter allowing the rod to sink more or did I just simply not adjust it far enough?
Also my main question is, When I shorten the push rod should the mark move up or down on the valve stem?
I shouldnt be having trouble with this as it seem pretty straight forward so I apologize.
Old Jul 17, 2010 | 08:12 PM
Bubba 95SN's Avatar
Bubba 95SN
Short=high side(toward intake) Long=low side(toward exhaust)
Old Jul 17, 2010 | 10:59 PM
Lazor05's Avatar
Lazor05
Thank you. Thats what I thought.
Old Jul 18, 2010 | 07:42 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
are you using a converted stock lifter or a solid lifter to perform the check?? if not all a stock lifter will do is collapse under the spring pressure and leave a false witness mark after rotating engine over.
Old Jul 18, 2010 | 01:40 PM
Lazor05's Avatar
Lazor05
Ahhhhh, ok that mkaes sense. Thats what I was thinking because whenever I would tighten the rocker 1/2 turn past 0 lash I would feel it give a little. Makes total sense. So I can convert the hydro lifter to be a solid for the purpose of the check?
Old Jul 18, 2010 | 09:12 PM
mjr46's Avatar
mjr46
^^yup, take the internals out, flip the plunger and I install a few small washers until I'm just able to get the retaining clip back in
Old Jul 19, 2010 | 06:56 PM
Lazor05's Avatar
Lazor05
Thanks for the help! but..... I still have a problem. I got the lifter to stay solid and then checked push rod length. I got the line to go right in the middle of the valve stem, but the rocker arm is hitting the stud. Not much just a tiny spot were the blue is rubbed off of the rocker and I can see metal but its still rubbing. Did I do something wrong or is it just my parts combo?
Trickflow studs that came with the twisted wedge heads
and procomp 1.6 rr
Old Jul 20, 2010 | 08:37 AM
ProTrickVic's Avatar
ProTrickVic
might need stud bosses milled down. i had to have that done. different heads but similar situation. post some pictures. hard to tell without seeing what you're doing.
Old Jul 20, 2010 | 08:51 AM
mjr46's Avatar
mjr46
and procomp 1.6 rr
did these heads originally come stud mount or did someone use a conversion kit?? if they were originally pedastal mount heads you'll need some milling on the stud bosses as Protrick states
Old Jul 20, 2010 | 06:36 PM
Lazor05's Avatar
Lazor05
I bought them new and they are stud mounts. Used the studs that came in the box with the heads from trickflow. Is it possible to run a thinner guideplate? Because that would give me some more clearance
