What is the point in having a dcc controller?
The only bad thing is their kit does not include a Circuit breaker. I drilled and tapped a hole in the lower intake above the water passeg at the rear of the head. Like how the small coolant hose for the EGR spacer attaches to on the right rear of the intake. I am also running the Explorer intake. The factory intake already has a plugged hole on the left rear.
http://www.jaycorp.com/pc-42-16-fan-...hermostat.aspx
My sensing wire just pushes between the fins on the radiator. It says to put it at the bottom at the outlet but I put mine toward the top at the inlet of the radiator where it is hotter. The one I have is an internal 50 amp breaker hense the 50 in the name.
Ted72787
Mustang Videos
Sep 8, 2007 02:17 PM
