engine misses
Old Jul 31, 2010 | 07:23 PM
alwayswright328's Avatar
alwayswright328
Default engine misses
I have a 92 mustang of which i just rebuilt the engine and have gt40p heads. The engine only had about 1200 miles on it when a fuel injector o-ring went out and began leaking onto the block. I pulled the upper intake, closed all the vacuum leaks and replaced all the injector o-rings. Now that everything is put back together the engine misses on the lower RPMs under a load. I replaced all spark plugs and the wires are all brand new... before i touched the injectors the car was running fine so I'm wondering if its a faulty injector or not... I would think that if i had a bad injector that the engine would miss all the time and not just on low RPMs. Any advice would be great!! thanks
Old Jul 31, 2010 | 07:51 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you have a vaccum leak
Old Aug 1, 2010 | 02:51 PM
alwayswright328
just replaced all vacuum hoses, intake gasket and pcv valve with gromet with no effect... I have no idea what could be causing this
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
vintageaion
Sep 8, 2015 10:45 AM
Gabe_mlcc
Sep 7, 2015 11:56 PM
