best cam for 347?
i currently have a 347 shortblock with eagle rotating assembly srp pistons that has been zero decked. i am swapping the stocker ported heads for a set of performer rpms and was wondering what you guys with 347's think is a good lift and duration to run.
here is some info
trans - automatic
rear gear-4.10
converter - 3,500 stall
intake- edelbrock torker 289 ported
induction-na, no power adders
any help would be appreciated
here is some info
trans - automatic
rear gear-4.10
I'm sort of 'old school'.
I'd do something about 240@.050 and all the lift I could get.
BTW, I'm talking solid roller.
110 for a center should be good for a start.
Oh, I know it's easy to say 'custom grind'..........
Custom grind, period. You can pick an OTS cam and it may work quite well, but a custom designed cam specific to the vehicle and engine/transmission package and the intended use will yield best performance.
junior04
Sep 28, 2015 10:53 AM
