TPS help
Old Aug 13, 2010 | 01:34 PM
jjw88mustang's Avatar
jjw88mustang
Default TPS help
My car has been jerking pretty bad at certain throttle positions so I decided to check the sensor. I found a write up on it and followed it the best I could. I hooked a voltmeter from my neg battery terminal then to the positive to the signal voltage wire. As I opened up the throttle it climbed from 1V to 5V but at one spot it would go to zero. Is the sensor bad? Thanks
Old Aug 13, 2010 | 01:54 PM
dillon1340's Avatar
dillon1340
yes that would indicate a bad sensor. the tps is a potentiometer so inside it there is a needle that swings over some contacts and where it goes to zero could be where the throttle is the most; around cruising speed, so it probably wore out there.
but i don't know that a bad tps sensor would make the car jerk at certain throttle positions.
Old Aug 13, 2010 | 03:17 PM
jjw88mustang
Alright thanks for the fast reply
Old Aug 14, 2010 | 06:56 PM
Bubba 95SN's Avatar
Bubba 95SN
Replace TPS
Old Aug 14, 2010 | 07:08 PM
86 5.0L's Avatar
86 5.0L
i had some jerking at certain speeds and rpms, cleaning my IAC with stater fluid worked.
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
