trans thread
Old Aug 26, 2010 | 04:11 PM
Bigedbronc's Avatar
Bigedbronc
Default trans thread
Is there a transmission section dedicated to just tranny related stuff or is that just stupid?I have to many quistions on trannys(stall,tire size,gear etc..)what do you think? Direct me.
Old Aug 26, 2010 | 05:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
gen disc
Old Aug 26, 2010 | 09:28 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
just ask the questions. What trans are you looking to ask about specifically?? Sounds like one of the autos....
great info at
www.clickclickracing.com
Old Aug 28, 2010 | 12:49 PM
Bigedbronc's Avatar
Bigedbronc
I have a c4,dont know the year.Fairbanks 3200 stall,reverse valvebody.Just would like to know the specs,how much abuse they can handle.
Old Aug 29, 2010 | 11:27 AM
uedlose's Avatar
uedlose
well that depends what else has been done. What internals are in it? did it have red clutches and good bands put in it? what servo are you running in the thing for the front band. what planetary are you running in it this is one of the weak spots in a C4. is it rollerized or still running the standard thrust bearing? There is lots of things that can be done to make them handle Big HP. 1000 seems to be the cut off and they dont last forever at that HP even with the best parts. 500 to 600 HP is not real hard for them to take with even mild build but it is not how much they will take but how long they will last. I run with a guy that has a real 1000 HP turbo mustang with a c4 he goes through 2 or 3 a year depending on how much he runs it and that is with the best of parts in it. But a turbo car make SICK torque. best thing I can tell you is keep it cool and run a deep pan get as much fluid in it as you can that is another draw back with them they dont hold much fluid.
Old Aug 29, 2010 | 11:30 AM
projectresto83
M.A.D. Motorsports
There are also some tricks you can do while building them to get fluid in other places of the trans that normally don't see much fluid pressure.
Old Aug 30, 2010 | 08:16 PM
uedlose's Avatar
uedlose
correct, unlike others I wont tell everything it takes to make them live at high HP. I had to work for it and I believe so should others.. I know A$$HOLE!!! LOL.. But at the same time I build a few for the local racers and if they new everything I could not make a $$. Hell I am still learning with everyone I build and then rebuild.
Doing well though I have one in a 9.20 car that is still street driven and it is holding up so far.
Old Aug 30, 2010 | 10:01 PM
projectresto83
M.A.D. Motorsports
^^ I know exactly what you mean. I plan on building a few once I get back to indiana next year and going from there. I have done alot of research on them and rebuilding them is a breeze.
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
KingRando
Oct 2, 2015 08:06 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
