Can my stock 94 cobra handle this
Im not to knowledgable about this, so i thought i would turn to the experts, namely, you guys and gals here.
I just recently got a steal of a deal on a Vortech V-2 Si Trim Supercharger and a Trick Flow 350hp Twisted Wedge kit, with Ford Racing Headers, and 30lbs fuel injectors. And was gonna slap it on my 94 cobra. And i would like to know if all the stock components can handle this combo, and if it cant what would be the more than likely first thing to go...... suspension......internal engine components?
Any help would be greatly appreciated. Thanks
If the tune is good then the engine "should" take both. But you'll want a better fuel pump (if the kit doesn't have one) and the 30's are too small.
You say you got a steal of a deal, I assume its used? If so is it pullied stock?
Yes, the top end kit has roughly 15,000 to 20,000 on it, and the s/c is the same, and it does have a fuel pump with it. And both of the items are in good shape, little wear on them. And yes, it is pullied stock. Once this is done it will be proffesionally tuned, i know how the 94-95 computers are. Since the 30's are too small would like 42's do the trick or higher?
Yeah, that'll be pushing close to the limits for a stock block of what's considered safe with a conservative tune. But it should be ok, but like mjr said, the transmission won't hold it. Not for long at least.
11-10-2015 11:39 AM
mungodrums
10-07-2015 04:01 AM
Dragonus18
09-09-2015 01:21 AM
M3hunter
09-05-2015 03:42 PM
