Engine question.
Old Sep 16, 2010 | 05:53 PM
67mustang302's Avatar
67mustang302
2 bolt mains are fine. The number of bolts is NOT the problem, it's the webs that are weak. When was the last time you saw a main cap come off from bolt failure? There are guys with blocks that are stock 2 bolt blocks(Fords, Chevy etc) making tons of power without issues.
The aftermarket blocks that go for 4 bolts, do so to distribute load more evenly throughout the main webbing, to prevent the block from cracking. Those blocks are also able to handle a substantial amount of power, far more than most people could ever afford to build.
Aluminum blocks are a different matter, since aluminum is weaker they have to have multiple bolts to distribute the load and prevent everything from squirming around.
Old Sep 16, 2010 | 07:42 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
i was referring to the style of block (stock vs BOSS or DART, etc...) not just the fact that theyre 2 bolt.
351C's are (mostly) 2 bolt, as well as a lot of 460's and (like you stated) make TONS of power.
so yes, the metal composition is the issue, not the number of bolts.
tmdm
May 2, 2021 02:49 PM
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
