over drive not working
i have a 93 gt 65000 org miles on it and overdrive stopd workn in it yesterday if i leave it in overdrive it wont shift just revss and when i put it in drive it will shift fine jsut stay in 3rd gear!?!?! idk if trannys going out or it got a vac leak somewhere?!?!
You more than likely burnt out the over drive band in it. I had this happen to me a few years ago.
My suggestion would be to take it to a tranny shop with a good reputation and have them rebuild it for you.
Tony
Tony
tranny is shot. dont just tell them you need a "rebuild" you will get sticker shock when it's done. you have some hard parts that need replaced too now, you'll need a new converter, and also the sunshell i believe is the od band clamps to. since the band wont grip it anymore it will have scored the shell and needs replaced too. your looking at about $1800
this is a great time to go either lentech aod, or a t5 swap
if you keep it auto get a stallion or lentech 3000 stall converter. no less or you'll be dissapointed.
if you go t5, you'll think you added 100 hp to the car
HIS S-197
Aug 10, 2015 05:47 PM
