Where is my coolant going?!
Old Oct 14, 2010 | 05:54 PM
Dj_Seph's Avatar
Dj_Seph
Default Where is my coolant going?!
Ok. I've got quite the problem. Since I used my heater during a bad rainstorm, my damn car seems to be losing coolant quickly. It's not dropping out of the car at all. NO leaks anywhere in the engine bay. I can't figure out where it's going. If the car is driven at low RPM's, it'll heat up and very quickly. At highway speeds above 50mph, it's perfectly fine. Besides that, it'll heat up. Also my electric fan will only come on randomly now. I don't know why's that. Can anyone help? Did a sensor die?
Also, what the hell am I doing wrong? In the past year I have gone through 6 clutch cables. Can anyone take a picture of where it should be routed? Maybe I'm routing it wrong? I have the whole firewall adjuster setup.
Old Oct 14, 2010 | 06:14 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
your most likely routed to close to the header, it goes on the underside of the mount and between the engine, as for coolant, make sure the cooling system is topped off and bleed properly, not doing such will create air pockets and hot and cool spots and cause temp sensors and fan sensing bulbs to not properly function
Old Oct 14, 2010 | 08:38 PM
Bubba 95SN's Avatar
Bubba 95SN
Take the thermostat and drill small hole put hole position at 12 oclock position when installing. Slowly refill and all air will pretty much be gone. Some thermostats have a bleeder some do not.
Old Oct 14, 2010 | 10:35 PM
Dj_Seph's Avatar
Dj_Seph
So the cable goes underneath the engine mount?
Old Oct 15, 2010 | 06:52 AM
mjr46's Avatar
mjr46
between the engine and the bottom of the mount, mine touches the underside of the mount
Old Oct 15, 2010 | 07:30 PM
Boss_Hotrod's Avatar
Boss_Hotrod
from the sound of it you have a blown head gasket. Heats up quick due to the combustion going into the cooling system and fine driving since air flows across the radiator cooling it off.
Old Oct 17, 2010 | 12:02 PM
Dj_Seph's Avatar
Dj_Seph
@Boss: I'd hope not. I just changed that two months ago. Also no coolant in the oil and no blue smoke coming out the back.
Old Oct 17, 2010 | 08:17 PM
Boss_Hotrod
If you have a way to put air into the cylinder, take the radiator cap off and put air into the cylinders (one at a time) and see if a bubble comes up. Also do a compression test. If the compression test passes you probably dont have a blown head gasket.
However you said you just changed them. Are you sure you put them on in the correct orientation?
Old Oct 17, 2010 | 08:54 PM
83fox50's Avatar
83fox50
if you cant do this method, go to Autozone and rent block tester fluid and tester.
part numbers 25739 and 27145.
this method allows you to see what is happening while the engine is running at operating temperatures.
Old Oct 17, 2010 | 11:31 PM
Dj_Seph's Avatar
Dj_Seph
I think you guys jinxed it.lol
