i need some help i need some pictures of how you have the pcv hooked up i got the bigger of the two hook ups hook up to the intake and that is as far as i know where it goes.
there should only be one vac line connector that comes straight up from the pcv. unless you bought the cheapo autozone one... if you did the "smaller" connection should be blocked off already i think. either that or get a cap for it.
yeah i think the one on my car is bad so i ordered a motorcraft one from oreilly's also can you tell me where on the block the negative ground cable goes the guy had it on the timing cover and i am not sure if that is the proper place for it.
