Radiationation
Hey just a few questions about aluminum core/tanks vs the factory copper ones.
My motor is completely stock and currently is leaking from the radiator and it's getting cold here so I can't run straight water. Would it be worth it to op for an aluminum core/tank? I can buy one with a copper core and plastic tanks from the local autoparts for like 87 bucks. My motor is not gunna last forever so I feel like if I go with the aluminum it might be better down the road...but on the other hand I'm broke as a *****. I know the plastic tanks won't stay together forever...Don't alot of drag car radiators have plastic tanks anyways?
drag cars..plastic tanks?? umm not anyones I've seen, most are of a solid construction/material, I bought an ebay 159.00 aluminum radiator for my 89 2 years ago, quality suprisingly was good and cools well as well as it works great
After dumping antifreeze into thy holy radiator I noticed some leakin from the water pump. I think I need to replace the gasket too. *sigh*
While I'm at it I wanna check the thermostat. Is it true that once you take it out you can't put it back in?
