looking to build 300whp all motor
#22
Yes, your trans will bolt up. Might have to change the flywheel though. Level 10 Transmissons in New Jersey and FB Transmissions in Long Island New York both build good Ford units. FB can build you a pretty wicked unit. You can google search them for the website. I had them build me an AO3 (AOD w/C-6 internals)and a Pro Torque converter for my LSC. Picked up 4 tenths in the 60 ft without even pushing it hard.
#23
I'm basically looking for a kit, ive rebuilt automatics before and im sure it would save myself a ton of money...
The closest track is over 100 miles from here so basically im just looking to build a good street machine... plenty of tires shredding power and 12s-13s are good enough for me
if i need to go a wholoe lot fasted ive got bikes to ride....
#24
i found a 76mm MAF not a 75,
http://cgi.ebay.com/ebaymotors/BBK-M...#ht_500wt_1182
also any generic 75mm tb work or is the more xpensive bbk one better?
http://cgi.ebay.com/ebaymotors/POLIS...#ht_5161wt_976
and with this setup or similar "stock shortblock, TFS top end kit (with Track Heat intake), swap out for TFS 2 cam, MEASURE PTV!!!!!!!!!!, 75mm TB, 75mm MAF, 30# injectors, longtubes, OR X, your choice of catback, 3.73's."
will i need a walbro 255 or are our stock pumps strong enough?
#25
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
logan409
09-26-2015 07:43 PM
