weld block?
i have shortblock that has 2 bellhousing bolts broken off..
this happened in the top of 3rd at 6000rpm and 165km/h (102mph) when the driveshaft snapped which caused the tranny to twist and snap also. The bellhousing was in four pieces.
the question is do u think the shortblock would still be usable?
im wondering if when the tranny was twisting the input shaft moving could cause damage to the crank??
it had a roller pilot beaing, the internal part and all the bearings were destroyed/gone...but the outer race is still there
the engine still turns over by hand with no problems
I would not try to weld it if it is nothing special if it is a good race block then I would be looking into having it fixed.stock I would not spend the money on just get another block. As far as the crank goes take it apart and have it checked if you need to reuse it.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
