Compression Numbers
Old Jan 2, 2011 | 02:19 PM
rocky3451's Avatar
rocky3451
Default Compression Numbers
I have an 89 Gt with stock heads and 1.72 rocker arms. The heads have had valve work. When I ran a compression test on the motor, I am got 185-190 psi. The car won't idle, but will stay on at higher rpms--acting like it still doesn't have compression. Are these numbers too high or do I need to be looking for another problem?
Old Jan 2, 2011 | 04:12 PM
slowmofive089's Avatar
slowmofive089
those numbers are fine. i would look somewhere dif. if you give it a litttle gas will it stay on?
Old Jan 2, 2011 | 04:43 PM
rocky3451's Avatar
rocky3451
Yes. It will stay running at around 800 if i give it some gas, but is reallllly struggling.
Old Jan 2, 2011 | 04:56 PM
slowmofive089
check your spark plugs and all that stuff . is it carb or fuel inj
Old Jan 2, 2011 | 05:08 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
clean out the IAC, check TPS voltage
might as well clean the MAF while youre at it...
Old Jan 2, 2011 | 05:44 PM
rocky3451's Avatar
rocky3451
it is fuel injected. I know the injector system is working.
Old Jan 3, 2011 | 10:27 AM
nitrous_bob's Avatar
nitrous_bob
did you do the rockers ? was it running before you added parts and now it isnt ? or did you buy it this way ?
after rechecking firing order, looking for vac leaks etc. i would pull the number 1 plug out and turn it over... make sure it is correct stroke (compression, not exhaust) and not 1-eightied
Old Jan 3, 2011 | 05:16 PM
rocky3451's Avatar
rocky3451
It was running very well before I decided to make it better.
Old Jan 3, 2011 | 10:54 PM
gotpower302's Avatar
gotpower302
Shouldve just got trick flow heads and stage 1 cam. Valve work on e7s is a waste of your time and money.
Old Jan 8, 2011 | 05:17 PM
rocky3451's Avatar
rocky3451
Thanks
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sep 23, 2015 01:28 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
