Best rear control arms??
Upgrading my suspension on my 90 GT 5.0. It's my DD and i doubt i will take it to the track. What is the best upper and lower control arms. I was looking at UPR and BBK. Which is better? and why.
While I do agree with adder on those being pretty much the best uppers and lowers out there for the fox, if the car is a dd then I think you should be fine with some solid tubular or boxed upper and lowers with poly bushings. Check out 50resto.com.( aka late model restoration ) they have a full upper and lower kit with hardware for like $150 or so. Just my $.02
I figured since im doing it i might as well do everything while i have things out. Late model resto is an amazing place, i get everything from there. They have a kit W/Red Lowering Springs, Subframe Connectors And Rear Control Arm Kit for $299.99. I figure id just get those. and do the shocks and struts also. Was thinking Mustang Tokico Hp Series Strut & Shock Kit. Im just trying to get some better handling out of this car without breaking the bank.
Get the FRPP C springs if you want a decent cheap set of springs.
I think you guys missed the point here... his thread is Best rear control arms?? To which I answered.
OP, you might want to consider what I posted up, for the simple fact that they are the best route to go, and it will greatly improve the way the car drives.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
