Trans fluid help
88 5.0 5 speed
So I know this has been beaten to death but I would like to here it from some senior members on here...
What is the best trans fluid for our cars and how much... Any every put some Lucas ATF additive or something like that
Thanks guys
Thanks guys
just because you have to do all the work to pull the shifter off and put it back on.
if the shifter is already off. then put both the fill and drain plug in the trans, driveshaft in place obviously. put in 3qts, then with the car level, take out the fill plug. a little should come out. once its slowed to a drip, put the fill plug back in.
ATF/Mercon 3 is fine, but syncromesh is the best synthetic i've heard, but not cheap at all. like $15 a qt
