EFI to Carb? Shed some light?!?!?
Old 03-24-2011, 12:05 PM
LiveFastDriveFaster
LiveFastDriveFaster's Avatar
Default EFI to Carb? Shed some light?!?!?
What drives people to take an efi motor and time travel it back to the old set up of carb? I really have no understanding for it. HP gain? or just a personal prefrence thing? I dont understand and sorry if this is in wrong place.
LiveFastDriveFaster is offline
Old 03-24-2011, 12:14 PM
tohoopty
tohoopty's Avatar
i converted mine to carb because the wiring was so hacked in it that it wasnt even funny.and i was going for a clean factor and its much easier to work on
tohoopty is offline
Old 03-24-2011, 12:45 PM
67mustang302
67mustang302's Avatar
Depending on what you're converting from and to, you might pick up a bit of top end hp, but usually not enough to matter. The biggest advantage is simplicity, a lot less crap in the engine compartment.
67mustang302 is offline
Old 03-24-2011, 01:59 PM
rwh129
rwh129's Avatar
I never understood that either, its just a personal prefrence thing I guess.
rwh129 is offline
Old 03-25-2011, 07:40 AM
LiveFastDriveFaster
HMMM didnt even think about it from the side of cleaned up. Simplicity I can understand, but to my knowledge carbs are a b**ch anda half to set up and get working properly. Again definatly notta knowit all kinda guy, but im building a 429 SCJ. This project is one that im sure will take till the wee old days of my life but its something i enjoy workin on. The last time my uncle and i sat down he told me to just buy a new carb. because the one i have would have to be reworked..... So i geuss ill figure out more when the time comes for putting that together.
Old 03-25-2011, 01:21 PM
67mustang302
Carbs can be a major pain to set up in some cases. You have to know what you're doing.
Old 03-27-2011, 11:43 AM
holyshift
holyshift's Avatar
Some reasons I switched
1.Cleaned up engine bay
2.Simple to work on,only 3 things to look for if your car wont run...fuel,spark,air,and on a carb car in my opinion its simpler to diagnose compared to having a bunch of sensors and what have ya.
3.Really not hard to set up as some think.
But I will say,if I was to have a blower or turbo car I would prefer EFI for the tuning aspect.
holyshift is offline
Old 03-28-2011, 09:10 AM
LiveFastDriveFaster
now see the not havin a bunch of sensors really makes sense. more so a mechanical peice then something ran of electronics and such...
Old 03-28-2011, 01:16 PM
tohoopty
tohoopty's Avatar
i got just 2 sensors on mine,but those are the oil pressure and water temp sensor so my stock gauges will work.then i got a power for my distributor and a tach wire.those are it other than alt harness and starter cable.its pretty clean under the hood and i pulled off the headers the other day and i didnt have to take anything off the motor to pull the headers out other than the spark plug boots.
tohoopty is offline
Old 04-01-2011, 11:40 PM
tinman
tinman's Avatar
The reason that I stayed with carb on my car is that I've worked with carbs for 40+ years and have a huge pile of parts around here.
IMHO, they will help the top end power by a bunch......
tinman is offline
Quick Reply: EFI to Carb? Shed some light?!?!?
