4cyl T-5 behind a 5.0 V8
Old 05-17-2011, 07:06 PM
Quickbird144
Quickbird144's Avatar
Default 4cyl T-5 behind a 5.0 V8
I didn't do this.
But ever since I purchased my car I've had a vibration around 1500-2000 rpms standing still and also around 60mph it gets real bad. I can feel it at my feet but it seems the direct source is coming from the transmission. So I got under and checked mounts and driveshaft blah blah. Come to find out I have a 4 banger T-5. Now to my understanding it's okay to use these, BUT the input shaft diameter is a smaller diameter than the V8's, there you would need the correct pilot bearing? Either The pilot bearing in there is for a V8 or there is none at all.
What are some of your guys opinions on this? I don't plan on making my car anything above stock to be honest. But I absolutely hate such short gearing it has.
Quickbird144 is offline
Old 05-17-2011, 08:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pull it out then and get a 5.0 t-5, I did just that when I had a 4 cyl t-5 for a while = hated it, you should pull it anyway to see if there is any or the correct pilot bearing to start
mjr46 is offline
Old 05-17-2011, 08:38 PM
nitrous_bob
nitrous_bob's Avatar
whats the tag number on it ?
nitrous_bob is offline
Old 05-18-2011, 12:20 AM
Quickbird144
1352-162
http://www.fordmuscle.com/archives/2...p/index2.shtml
Old 05-18-2011, 01:19 AM
tohoopty
tohoopty's Avatar
i liked the 4 cyl t5 i had in mine.it did ok with 3.27s
tohoopty is offline
Old 05-18-2011, 09:53 AM
Jfsram
Jfsram's Avatar
With the smaller input shaft in the bigger pilot bearing. The disc is probably never centered causing a vibration.
Jfsram is offline
Granatelli Sales
03-25-2016 08:01 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 4cyl T-5 behind a 5.0 V8
