T5 fluid refill hole?
Old May 29, 2011 | 12:20 PM
stdyhand's Avatar
stdyhand
Default T5 fluid refill hole?
Where is the refill spot on the T5 Tranny? I just replaced my throwout bearing and lost about 2-3 quarts of fluid and need to refill it. What is the best or most accurate way to do it?
I was told it was on the side of the tranny, but not which side. Both sides appear to have 2 plugs screwed into the side, one higher than the other. And they screw in/out with an allan wrench.
If this is the wrong spot please let me know.
Thanks for the info!
Old May 29, 2011 | 12:31 PM
AdderMk2's Avatar
AdderMk2
Banned
fill plug is in the side, and it should be a 3/8" square. Easiest place to fill from is the shifter though!
Old May 29, 2011 | 12:56 PM
Quickbird144's Avatar
Quickbird144
+1
No homo.
Old May 29, 2011 | 06:22 PM
ALMOST STOCK's Avatar
ALMOST STOCK
The top plug is the fill hole, you can remove it with the square shank on a 3/8" ratchet end.
I remove the plug then route a 3/8" hose with a small funnel on one end down the passenger side to the fill hole and push the hose inside and fill. But that's just me .
Old May 29, 2011 | 09:20 PM
holyshift's Avatar
holyshift
X2 on the shifter location.
Old May 29, 2011 | 09:57 PM
stdyhand's Avatar
stdyhand
If you fill it from the plug, I assume you fill it until it runs out.
If I use the shifter to fill it, how do I know when its full? Will fluid start to fill the shifter area and will a little permatex work to seal the shifter?
Old May 29, 2011 | 10:11 PM
1988TTOP's Avatar
1988TTOP
i fill it though the shifter hole i take the fill plug out and fill till oil starts coming out permatex is fine to seal it back up
Old May 29, 2011 | 11:24 PM
ALMOST STOCK
stdyhand
If you fill it from the plug, I assume you fill it until it just runs out.
Yes fill until it just starts to run out.
If you're going to remove the plug to make sure that it's at the right level (full )you might as well fill it through the plug hole has always been my thought process.
Old May 30, 2011 | 01:14 AM
AdderMk2's Avatar
AdderMk2
Banned
When I had my T-5, I had drilled a 1/4 NPT hole towards the front of the shifter base, and used that as a fill point, So I didnt have to keep taking the shifter base off.
Old May 30, 2011 | 10:27 PM
TexasTanker19kilo20's Avatar
TexasTanker19kilo20
Goldilocks
I used this pump from O'Reilly Autoparts http://www.oreillyauto.com/site/c/de...0728&ppt=C0164
Cost about $9 and it screws to the top of the bottle, put the car on jack stands, then laid on my side pumped fluid in till it came out of the fill hole, put the plug in with no sealant then called it a day...too easy!!!
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
jrrhd73must
Oct 2, 2015 09:17 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
