Best code reader for my 95 GT
Old Jun 15, 2011 | 06:03 AM
Detector's Avatar
Detector
Default Best code reader for my 95 GT
When I start my 1995 GT I get 5 sets of 5 beeps after the initial bongs/chimes of starting the car. I am wanting to get a code reader to help diagnose any problems. I did a search and found some older information about coder readers and that the 1995 5.0 uses OBD1 reader, but I was wondering, since the were older threads, if any new information was available for coder reader options. Possibly something newer and better? Any suggestions?
I've had concerns because my car sounds very healthy but just doesn't run like it should. When I punch it it feels like it is starving for fuel, air or something. I put in a new fuel filter and that didn't help. It's like something is holding it back and I figure a coder reader might enlighten me.
Thanks
Old Jun 15, 2011 | 08:50 AM
Bubba 95SN's Avatar
Bubba 95SN
http://sbftech.com/index.php?topic=2471.0 This should explain it.
Old Jun 15, 2011 | 09:02 AM
AdderMk2's Avatar
AdderMk2
Banned
Here is the best code reader for your 95 GT!
Old Jun 15, 2011 | 09:21 AM
Venomantidote95's Avatar
Venomantidote95
I use the innova 3145, it has an digital screen you dont have to count the blinks on the light! It tests and then displays all codes!
Old Jun 15, 2011 | 11:31 AM
Detector's Avatar
Detector
Sorry if this is the wrong place, again, to post these questions. I seem to be having a hard time finding the proper place to start a thread.
Well I got a 3145 and got a bunch of fuel system lean codes. I get a code 172(HEGO(HO2s) sensor lean) and 176 and 181(Fuel system at rich adaptive limit at partial throttle/System Lean) 189(system lean). I guess that might explain why it feels like the engine is starving for fuel.
Old Jun 15, 2011 | 11:37 AM
Venomantidote95
What is your Fuel pressure idle and under a load? do you have an adjustable fpr, stock injectors or upgraded? stock fuel pump?
If all thats good then you might wanna replace your o2`s.
Too much fuel dumping from a lean reading being factored in can cause it to lay down also!
Old Jun 15, 2011 | 12:41 PM
Detector's Avatar
Detector
As far as I know everything is stock. I'll see if I can check the FP pressure at idle and under a load.
Thanks
Old Jun 15, 2011 | 05:51 PM
ttocs's Avatar
ttocs
I thought the beeping was to tell you that either a warning light was out or an airbag problem.
Old Jun 16, 2011 | 04:44 AM
Detector's Avatar
Detector
I get no codes or dash warning lights. I get the normal door open chime and then a series of 5 long beeps, 5 times.
Last night I changed the air filter while cleaning the MAF and also replaced the Ambient Air Temp?(the one right after the MAF), and also the ETC sensor and now it runs a whole lot better.
Old Jun 17, 2011 | 03:21 AM
Mr Speed Master Gt's Avatar
Mr Speed Master Gt
I experienced the exact same "starving" problem as you and the lean codes also showed up on my code reader.
If i may suggest something - disassemble your MAF sensor im willing to bet the two little sensors are dirty. Thats the problem i found with my 94GT - they (the little sensors wires) were dirty as hell!! Now my car screams down the road!!
Hope this helps.
