finally back to the boards (pics)
#21
well I'm talking about the guys that know every trick in the book, have 20 oem cams all profiled and pick the best one, ton's of "sneaky" bottom end work, only running one compression ring, and limited oil rings, and all kinds of crazy junk.
pretty sure most of those run low 11's high 10's on skinny DR's or slicks
NHRA stock eliminator cars run with full sets of rings, stock heads, no 'power adders'. Nothing really crazy about them.
The cams they use are stock lift and any duration, most run about 245-250 @.050 however.
NHRA classes for 5.0 FOX body cars are usually M/S, N/S. M/S record now is 11.98 but there could well be a quicker car someplace on the planet.
Go over to NHRA's website sometime and read the rules, they are VERY restrictive.
I can tell you from ekperience that those guys go as qick as they do by getting the chassis working just right and using tire/gears for the best effect......
Those cars are also very expensive, start maybe about 30 grand.........
#22
No way.
Guess I do need to educate myself a little more on it, haha.
#24
Yep. Competitive stock eliminator racers have like $5000 'stock' heads.
A lot of the engine work is the balancing/machine work.
That's why a good car for the classes that a FOX mustang could run in ends up being a $30K car..........
#26
tinman, to me that is not stock then since it takes modifying and machining to get to where they need to be. i pulled motor from an 87 took some accessories off and im trying to see what i can do
#27
Gotta think Epic... everyone reads a set of words a little different than others so the interpretation can be blurred from one person to another...but that is the calass that they compete in....there is a small.....very small class that has people that have not touched the bottom end at all...
hell I know stock...but my version of stock is different than others...if its OEM..(gt40's, explorer,cobra,eaton) it is still stock lol but other are a little more exact than that...
#29
True, there is 'stock' as in NHRA legal and then there is stock as you are saying with the OEM type combos that maybe the factory never offered but should have.
As a former stock eliminator racer I'll tell you that 'stock' can take on some very strange meanings, expensive ones.
I really like the idea of your meaning as long as non OEM power adders are left out.
Ever heard of an acid ported head/intake? That'll give you an idea of where some of that money goes..........
#30
