5spd question?
Well i put a clutch in my 87 and while under it the tag id number came out to be a 5spd from a 93 cobra, it says the first gear ratio is a 3.35 and i have a 3.73 rearend ratio.. Well we are going turbo later this year and will definatly be swapping the rear!
Is the info i have above correct? F9ZR-70003-AA-rep is the tag id. I~m not worried about the 5 speed breaking from the turbo cause we will then go with a c-4!
yep all factory WC T5's have a 3.35 1st gear, only the T5Z has a 2.95 1st.
the difference between a Cobra and a standard is the front bearing style, Cobra is needle style, all others are just barrel rollers.
let me know when you want to off the T5 im always looking for ones to rebuild or keep for the FFR
So no definate answer? maybe someone has the exact info, just figured there are way more informative fellows on here about 5spd than myself......... I use to know a bit but havent had or been a stick man since i was 18 now have one again. but once we find a c-4 i will no longer be one again lol.
