which carb
This is a very complex question.
What heads, cam are being used?
What is the wieght of the car? What type transmission is being used?
If it's an automatic, what stall is the converter?
What RPM range is the engine going to be operated in?
world windsor sr. with port work, lunati voodoo solid roller with a 640 lift..not sure of the weight...c4 trans 3 speed with a 3500 stall 3000-7000 is the rpm range
C.I.D. x RPM/3456 = Max CFM at 100 Volumetric Efficiency. Few engines reach 100% V.E. without forced induction.
347 x 7000/3456 = 702.8 cfm
Estimating 90% V.E., you get 632 cfm. My guess is that you will Like that 670 Street Avenger, so long as you get it tuned properly. I doubt it will be exactly right straight out of the box.
That math formula is a nice piece of work but I don't think it really applies in this case.
I know of several very good running 430+C.I.D. engines (brand C) that are uaing 1250's.....
On the other hand more than a couple 306's have used 750's very successfully......
The whole reason to use the formula is to retain low end driveability.
On the other hand, you can turn a 306 to 8500 rpm and use every bit of 750 cfm flow. You also have to take into account the percentage of over capacity.
Sticking with 100% V.E. for simplicity, you can run 750 cfm on a 306ci at 7500rpm and miss by 12% and still be better off than that same 306ci cammed for 6500rpm having the same 750 cfm which would miss by 24%.
That's a HUGE difference in the match of flow to demand.
In short, you can't compare based on displacement alone. It's the package that counts. Fortunately, we had his cam range and displacement to work with. The lack of specifics on porting and such makes a good argument that he won't achieve 100% V.E. since a good NASCAR or pro NHRA builder struggles to get there. I'll stand by my math.
bradleyb
Nov 27, 2015 07:50 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
