efi spyder intake info
so i picked up this intake for cheap. for future build
did not come with the fuel rails, what fuel rails fit for stock lines? or will stock fuel rails fit?
stupid question lol if i put this intake on stock heads it would kill all power wouldnt it.
thanks
thanks
that intake is WAY too big for a small CI build. I would strongly suggest you do NOT use it yet. The rails you want are from CPRparts.com assuming you have their manifold. What you need to do is verify what style of injector boss you have. If they are angled, or straight up. The only other rails I found that fit the EFI spyder are the Edelbrock rails.
i knew it would be way to big but i had to ask lol
do the edelbrock rails have fitting to hook up to factory lines?
mine has the efi spyder elbow that they have but the intake has no markings
looks like a high rise air gap intake
has two screw holes in the sides that look like the same as the factory rails ill get a pic of it up tomorrow.
