MAF question
I took a few parts in on trade for my old rear end I swapped out of my car, 2 MAF sensors, a BBK short intake, K&N air filter and it was either 24 or 25 pound injectors. I am planning to swap to MAF when I can find a computer, and I googled the part number on the MAFs as they are the same and came back to 93 cobra's. The number is e9zf-12b579-aa. I am wondering, will i need to find a 93 cobra computer in order for this to work or can I go with a regular GT computer. If so wheres the best place to source one? And can I use a plug off of a different ford such as a ranger? Plug appears the same but havent checked fitment yet. I also assume I'd have to switch the fuel injectors if I use the cobra stuff, correct? Thanks guys
hmm ok yeah I see thats what the part number comes back to now, just find it interesting they both have the same housing, hopefully the car will work ok with these housings, thanks guys
Like I said, the sensors can be swapped into other housings. I am currently running the same sensor in a Cobra 70mm housing. Its not the best setup since the sensor is trying to read the amount of air comming thru a 70mm and reading it for a 55. It does work however. If you do have a 70mm housing you can get the right sensor for it and work perfectly fine.
