Upper and Lower intake
Old Sep 25, 2011 | 09:11 PM
Rage91GT's Avatar
Rage91GT
Default Upper and Lower intake
I have a 5.0 GT stock.. I am thinking of adding a GT40 upper and lower intake and heads.. Would this be a a direct bolt up with no mods required? And if there are mods what would they be.. Also what kind of power gain can i expect.? Thanks for your help..
Old Sep 27, 2011 | 03:50 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
They are all the same but it kinda depends on which GT40 intake you are going to use....There is the cobra, explorer, and tubular GT40.... They are direct "bolt on" but depending on which you use the vacuum lines will need some slight rerouting. Nothing major....
If you are just doing the intake the power gain will be little but slightly noticable. You will notice more once you swap out the heads too...
Old Sep 27, 2011 | 06:49 PM
nitrous_bob's Avatar
nitrous_bob
thats a super broad question, but you can gain up to 75-ish
thats with a tubular, and good aluminum heads. as a second choice, iron gt40's, the real ones. 3 hash marks, that come off cobra's, or lightnings
think about port matching the heads to the intake, and the lower to a 1252??? i think 1252 is the one.
also check the gt40 lower, they are VERY different
you want the part number to end in "AA" NOT "BA" near the dizzy cutout
The BA is only .96" x 1.65" and the AA is 1.00" x 1.80" , no sense porting what you dont need to.
FivePointToTheOh
Sep 14, 2015 03:35 PM
MusicCity615
Sep 12, 2015 07:05 AM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Dragonus18
Sep 9, 2015 01:21 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
