how do u know
Old Nov 1, 2011 | 08:29 PM
killakane1427's Avatar
killakane1427
Default how do u know
how do u know when your heater core is going bad
Old Nov 1, 2011 | 09:50 PM
mustangGT86_05's Avatar
mustangGT86_05
You smell it when you turn the vents on, mostly with heat on, more than normal moisture on the windshield when running, and you'll normally find excess coolant in the heater box to drain from the passenger side firewall in the engine bay. You may also find a wet floor board
Old Nov 2, 2011 | 06:52 PM
5.0muscle's Avatar
5.0muscle
^^^^What he said and if you have a nose for coolant you will smell it before anything else.
Old Nov 2, 2011 | 09:16 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
it leaks, plain and simple, and out the evap drain hole it rolls
Old Nov 5, 2011 | 09:22 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Either it leaks or it gets clogged (no heat)
Old Nov 8, 2011 | 07:52 AM
nightcrawler52's Avatar
nightcrawler52
Or you're riding shotgun and you get hot coolant all over your legs.
Old Nov 8, 2011 | 10:27 AM
mustangGT86_05
^ normally you'll know before that happens since the heater box will drain
Old Nov 9, 2011 | 10:57 PM
nightcrawler52
I'm saying from real life experience.
