Need some upgrade help ASAP!!!
So i have a 90 GT that has a trick flow upper and lower intake, 70mm throttle body, cold air intake, trick flow underdrive pulleys, headers, custom side exhaust with h-pipe. I just got a bbk adjustable fuel pressure regulator and was wondering if i should go with a 155 or 190 fuel pump. And also should i get a 76mm mass air calibrated for the stock injectors? I am running the stock 19#injectors. Or should i do bigger injectors and the mass air? Also what should i run for fuel pressure once i put in the fuel regulator and fuel pump. Any help would be greatly appreciated!!!
I would suggest either 110 or 155lph fuel pump for what you have, along with a 73 or 76mm mass air flow sensor. If you plan to upgrade your heads, I'd go to the bigger sizes, and if not, stay with the smaller sizes. You'd need 24# injectors with better heads. You shouldn't' need the adjustable fuel regulator, but 39psi or thereabouts is where it belongs.
Oh boy......
It's the 15$ dollar part you brought up that i'm talking about??? What part store sells them that cheap??? I bought this car used with many small issues. One of those issues is a faulty MAF.
For what he has, a 70, 73, or 76, would all work great. I don't really care which brand name, or from where. I personally ran a C&L 73mm for over a decade on a car with 300 rwhp, and it never gave me a problem. When I changed to 24# injectors along the way, I changed out the flow tube for $30, and it always worked perfect.
