AOD
Old Dec 11, 2011 | 09:33 PM
RICEBORDEAUX's Avatar
RICEBORDEAUX
Default AOD
Who and where can I get a performance good AOD kit needs to hold at least 800hp and still be able to be driven on the street...thanks in advance
Old Dec 11, 2011 | 10:15 PM
Venomantidote95's Avatar
Venomantidote95
Www.becontrols.com sells the parts you are after but its in seperate kits direct drive set hardened stub shaft etc no one certain fix all kit! They offer aftermarket drum assemblies and I believe you can buy the wide ratio planetary gearset too... When I looked at all the upgraded parts I needed fo rm r my aode it was around 800$ for everything but thats to get to where you want! I opted for a normal rebuild kit to insure I could pull off the build before I dropped that much on parts!
There are no special tools required to teardown and reassemble either!
The alto blue dd kit takes you from 5 steels and frictions to 8 for added output!
Old Dec 11, 2011 | 10:18 PM
mattdel's Avatar
mattdel
The thought of an AOD behind a motor like that makes me cry.
Old Dec 12, 2011 | 01:34 PM
Venomantidote95
I have a buddy with an AOD behind a 408 that runs 6.0s with 3.55 gears! Does that make you tear up lmao! He can drive anywhere and as far as he wants without spending half a weeks pay doing so.
Old Dec 12, 2011 | 02:52 PM
DeathRattle's Avatar
DeathRattle
Venomantidote95...6's AND streetable?! No offense but is that 1/4 mile or 1/8 mile?
Old Dec 12, 2011 | 04:43 PM
nitrous_bob's Avatar
nitrous_bob
only 1 answer.... lentech
get a warranty and everything
Old Dec 15, 2011 | 05:18 PM
RICEBORDEAUX
Gotta taken care of and if you don't know there's people building AOD's that can handle 2000hp but for some you we'll you know everything..Just like I seen a stock block turbo 5.0 go into the 8's in the 1/4mile several times before the rods went through the block...
Old Dec 15, 2011 | 06:28 PM
bluebeastsrt's Avatar
bluebeastsrt
X2. This is what I'm doing as soon as money allows.
Enough said!
Old Dec 18, 2011 | 02:22 PM
holyshift's Avatar
holyshift
x3 on Lentech,getting rid of my c4 this year and having my buddy build me an AOD the way he built his old one. He was runnign 8.90's in the 1/4 with his nitrous windsor motor. I think Ill be fine with it,plus OD....come man....OD!
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
CarrieS
Sep 1, 2015 01:00 PM
TAC_Sisco
Jan 8, 2004 06:33 AM
89 GT
Nov 18, 2003 03:24 PM
MustangGT95
Jul 31, 2003 02:56 AM
