1997 mountaineer 5.0
As it reads i got a 1997 mountaineer 5.0 i read people often want these for the heads, im just wondering if anyones is using this block??
Im putting mine in a 1993 lexus sc300, after building it and mounting this singal HOLSET H1E turbo
I forgot to mention that mine did too. Mine didn't have a dish in the pistons like the my 93 pistons did. You top that off with a gt40p head that is at 59cc's and you have more than a 9:1 motor like advertised. I figure it is a bit more than 9:5:1. That is probably why it ran so damn good.
Man sorry guys i havent been able to get on this site for a few days only could read your replys in an email... but im glad to here you guys are using the same thing. How ever mine is going in a SC lexus lol! But i got the motor out last week took the tranny off this past monday the block is going on a stand and getting stripped down soon... ill take some photos of the build as it happens im completly new to the ford engine so any tips or need to know info would be great and if anyone could tell me how to get this damn fan clutch off the would be outstanding lol!
Put the belt back on, hold the pulley and try it.
wait, being a 97 block, it may have the kind that needs to be beat off with a hammer and wrench. If you have an air chisle, it does it pretty easily. Still would help to have the belt on either way. I can't remember if they are reverse thread or not. If it is, it usually says it on the fan shroud which you probably don't have lol. I don't think they are though.
If it is the one I am thinking about, the water pump has threads on the shaft and the clutch has a big hex that threads onto it. You shouldn't be able to remove the plastic fan blades without having the clutch off of the water pump. If you have tried wacking it with a hammer and no go, you will probably need a chisle to get it off. An air chisle can hit a lot harder than a big wrench and a small sledgehammer.
As far as holding it, that is what the belt helps you do. The more pressure you are able to get on the belt, the more the backside of the belt will let the water pump turn.
My engine is a freshened up 96 and it runs great. I often run it up to 6K rpm with no problems. It has some work done to the GT40 heads that came on it and a TF Stage 1 cam.
The only bad thing about these engines is that the pistons are not forged like the 87-92 engines were, but unless you run N.O.S. or a lot of boost, it will be fine.
Yes i will giving this fan clutch another try this week and then my whole motor will be getting stripped down, it will be getting forged internals and a lightened crank havent decided on a cam yet but i want to use my HOLSET H1E turbo and would love to see 30+ psi or 50 if the block will alow it... i have a company here that makes stainless steal gaskets for anything so i can boost proof the whole motor and i think with a 76mm throtal body and 4 1/2" down pipe things could be interesting but will see what happens i need a tranny and to fit the motor figure out ignition blah blah... you guys know this stuff power from lexus to ford coils lol gonna be fun
