What to do first
Well Im new here just made my first post in the introduction thread so I figured Id go ahead and start asking away.
Bought the car with everything already done. But this is what I know.
93 302 5.0 forged stock rods pistons
Heads 1975 351 windsor heads with roller rockers arms 1.6 ratio comp cams brand adjustable.
Cam Eldebrock performer rpm 302 hydraulic flat tappet -with lifters new 2007
Intake Eldebrock performer rpm alum intake
What I am looking to do is get a little more power for not a huge amount of money. If its possible. I was looking into a set of heads. Have done some reading and I think the edlebrock rpm heads is what I would like. But I need to know if they will just bolt on to what I have and no further item bought. If they are just straight swap. I am going to be building a set of zoomies for the car. I have to make those cause other headers will not work with the frame clearance. I know I will lose some back pressure because of that but its what I gotta do. If anyone can help me out and give me some input on what im wanting to do here I would greatly appreciate it.
Thanks again
Aaron
Thanks again
Aaron
Anyone ever went with the pro com 190 cam?Talked to a guy and he said these are a new design that they have put out. Or at least the set he is selling is a new design.
Thanks
http://www.competitionracingsupply.c...led_heads.html
Thanks
That's a sweet ride always wanted to build a rat rod. The eddy heads will bolt on fine also look into trick flow tw heads I got mine on sale at summit for just under a grand. Do some searching in forums and see what suits your needs plenty of info out there.
look at the trickflow cams. they are nice and very decent price $180 i think and split duration
i dont think you want edelbrock rpms, i think you might want performer 5.0's, those are the 1.9/1.6 valved heads
why do you think your '93 motor has forged pistons ? if yes...they are not stock. '93's had hyper pistons FYI
nice ride...welcome
nice ride...welcome
Don't knock on hyper pistons. They were economical. More silicon is good for thermal expansion... but not for strength. Ford did what they did.... and I'm amazed my ranger has a 4-banger aluminum block.
