dicontinued brembos....
So i have a 13 inch rotor and 4 piston caliper brembo set up on my 95 gts. its called the grand turismo kit. I called them up and they said its discontinued.. i cant believe this for how much these kits are and i only used one set of pads. what should i do? for now im just gunna buy all stock and put that back one so i have brakes for the meantime.
Unless another company is making replacement pads for the kits, you might be screwed. You can try to contact Bendix and see if maybe you can get some custom pads made up, or if they make a set that will fit into your calipers as designed.
They're an Australian company, so account for time changes if you intend to call them.
http://www.bendix.com.au/node/19505
Try calling Brake Pros(Owned by Stillen) in Santa Ana,Ca. They used my Evo X to get measurements for my brembos. They manufacture a lot of pads for companies. They are also the sister company known as tubular solutions that make 70% of all sway bars.
Here is the website. http://www.brake-pros.com/browse.asp?c=BR&s=PADS
If you have any issues hit me up. My buddy is the chief engineer over there. I can email him if you cant find what you are looking for.
