Some mods i need to know if there a wast of money.
And when you say H/C/I are you talking about Heads/cam/injectors?
Heads without the proper full intake set-up, cam and fuel system will do barely any good. Wanna go cheap get nitrous.
A set of gt-40 heads and intake, with a semi-decent cam, and intake will net you as much horsepower as a choked off good set of heads....
But with a choked off set of heads you can upgrade later...
Google some stuff.
Google some stuff.
i disagree on the GT40's i like them
real gt40's , NOT p's are a good head. but not box stock. they need some porting on the exhaust and a good valve job. helping out the intake turns is a good idea too.
after spending $300 on the heads and another 200-300 on port work though....you can have a set of used aluminum heads for not much more.
im a big fan of gt40's, but if you shop around...you can get a better deal on used aluminum. be careful that someone didnt port them in a way that doesnt work for YOU though. what i mean is...on a stockish cam and typical streetcar setup...FLOW means NOTHING !!!! its all about velocity
a head thats TOO ported can slow you down because the velocity will suck
