What type gas put 1991 Mustang LX 5.0?
Old 05-08-2012, 02:59 PM
Em_DynamicTurbo
Em_DynamicTurbo's Avatar
Default What type gas put 1991 Mustang LX 5.0?
What type gas put 1991 Mustang LX 5.0? I've been putting 93 octane for a few months now. but i wanted to know if i can put 89 or 87
Em_DynamicTurbo is offline
Old 05-08-2012, 04:28 PM
motorman524
MF Informant
motorman524's Avatar
Based on your sig, I'd think you know the answer to your question.
motorman524 is offline
Old 05-08-2012, 04:43 PM
Em_DynamicTurbo
Well, unfortunatley I don't know the answer. And I was told to put 93. But I wasnt sure, hence the Post.
Old 05-08-2012, 05:00 PM
newpony
newpony's Avatar
GasStations ive ben to only sell 91. i belive is depends on you tuning ,yet it clearly states on the fuel door)unleaded)i'm guessing ,not sure i always use 91, whats recommended.
you may need some 110 still depends on tuning and motor
newpony is offline
Old 05-08-2012, 05:12 PM
The_Dude
The_Dude's Avatar
My stock '91 5.0 LX seems to run fine on regular.
The_Dude is offline
Old 05-08-2012, 08:37 PM
craig71springsport
craig71springsport's Avatar
Try alcohol.
craig71springsport is offline
Old 05-08-2012, 10:15 PM
dwb91lx
dwb91lx's Avatar
My 91 shop manual (I think) & owners manual says 87 octane regular unleaded...My recent Bama Chip purchase may get 92 octane next fill up to try out the 91R tune.
dwb91lx is offline
Old 05-09-2012, 04:19 AM
mustangGT86_05
mustangGT86_05's Avatar
You can't just go and buy leaded fuel anymore, I think the only way you can get it is to buy it as an additive. They only say unleaded because lead wrecks catalytic convertors yet I see all the time people for some unknown reason have the conception that high octaine fuel is leaded. And 110?! That is extreme, if he required 110 I doubt his car would be street legal.
Consider this, the ho 5.0 is a high compression engine, so that alone tells me put high grade in mine. Octaine is the resistance to detonation, if you predetonate most electronically controlled engines retard timing to compensate, this will kill your performance.
There seem to be many misconceptions about gas, but a higher performing engine will need something more than just 87.
mustangGT86_05 is offline
Old 05-09-2012, 06:43 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
put diesel fuel in it.........
mjr46 is offline
Old 05-09-2012, 08:01 AM
majohns
majohns's Avatar
i know with with my last mustang i had an sct tuner and on a 93 octane tune you have to run 93 or higher because it would start pinging. this was in a 4.6, i would assume it would be the same on the 5.0 though. i personally run 93 in my cobra stock engine. but i went from 9MPG in my truck to 18MPG in my car so the cost doesn't bother me to much. all in all, you can safely run 87 on a stock tune but if you have a 93 tune run 93 or higher on that tune. you can also mix about 5 gallons of race fuel with your 93 and make it even better plus it smells awesome.
majohns is offline
Quick Reply: What type gas put 1991 Mustang LX 5.0?
