TB question
Old May 14, 2012 | 09:18 PM
majohns's Avatar
majohns
Default TB question
if i put a 70mm tb on what else do i have to do?
Old May 18, 2012 | 10:53 PM
nitrous_bob's Avatar
nitrous_bob
hook the throttle linkage back up, plug in the TPS harness, and plug in the IAC harness.
thats it really, you could set the tps if you really wanted to
Old May 19, 2012 | 01:56 AM
mustangGT86_05's Avatar
mustangGT86_05
I think he's asking if he'd need to upgrade his fuel supply, but I really can't field this question properly. Though if you're using a stock manifold there isn't too much point to a larger tb
Old May 19, 2012 | 08:20 AM
reldla1996's Avatar
reldla1996
If you have an EGR spacer, it needs to be the same size as the TB, and would need upgraded at the same time. They are both simple to install.
Old May 20, 2012 | 04:22 PM
majohns's Avatar
majohns
but i wouldnt have to change my mass air or anything would i?
Old May 20, 2012 | 05:48 PM
mustangGT86_05
Would be best as your stock one would act as a restrictor and limit the ability of the new tb
Old May 20, 2012 | 08:30 PM
majohns's Avatar
majohns
ok so realy what i need to do is change intakes and mass are to at least equal my TB and then match a egr spacer? tell me this out of curiosity does a TB spacer do anything?
Old May 20, 2012 | 09:39 PM
reldla1996's Avatar
reldla1996
Depending on your intake, and modifications, you may not have an EGR spacer. The EGR valve bolts to the EGR spacer on most factory 5.0 engines, allowing the EGR gases to enter the intake air tract, reducing emissions. On the cobra intake, at least for the 87-93 model years, the EGR spacer was built into the intake manifold and therefore did not require a separate EGR spacer.
Old May 20, 2012 | 10:38 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
Your intake bore needs to match tb. The maf needs to at least match. Bigger would be better.
What I would do if I were you is put a dry hundred shot on the car and be done with it until you are ready to upgrade the motor. If you do start buying parts for a stock motor, they might as well be big enough for what you want to build. Otherwise you will be buying them again.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
