startin problem!!
Old Jun 15, 2012 | 04:46 PM
sitnhigh's Avatar
sitnhigh
Default startin problem!!
i have a 95 cobra it starts but cranks slowly. then i drive it about at least a mile or more then shut it off come back out to start it after sittin about 10 to 15 min it cranks slowly but wont start n if i keep tryin to start it the ground wire starts smokin on the battery! any suggestions here? please!! thx
Old Jun 15, 2012 | 04:49 PM
sitnhigh's Avatar
sitnhigh
i really need help on this like to get out n cruise this weekend!!
Old Jun 15, 2012 | 05:30 PM
mustangGT86_05's Avatar
mustangGT86_05
Make sure your terminals are tightened and aren't corroded, if you can twist the connections at all they aren't tight enough
Old Jun 16, 2012 | 09:22 PM
Js88lx's Avatar
Js88lx
make sure the ground wire is grounded correctly and not corroded..., I think your starter is going out!!
Old Jun 17, 2012 | 09:27 PM
mustangsneverdie's Avatar
mustangsneverdie
if you have a multi meter on hand, check resistance on the starter wire. it should have no more than 1 ohm of resistance
Old Jun 18, 2012 | 06:13 AM
van-swink85's Avatar
van-swink85
Clean the connections on the wires and where they make contact to starter an battery, i would go ahead and check all grounds just to be sure
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
