valve springs
valve springs
Alright guys i have an e cam and i dont know what springs to get to meet the required spring pressure and i was wondering if i could get springs with more pressure than the required amount, and how would that benefit me, any advice is appreciated
http://www.alexsparts.com/sb-ford-gt...it-hyd-roller/
I've got around 1500 miles on my setup so far, and have ran the car all the way to 6800 rpm and it still pulls. Hope this helps.
Thanks for the response oatburner but springs are gonna have to wait i just got gt40 heads and roller rockers not sure if they are 1.7 or 6 gonna find that out today, and when u say the bolts were bottoming out in the head what do u mean by that?
really? that's the dumbest thing I've ever heard. Actually yes he will benefit from it, due to the fact having a better seat pressure will keep your valves closed @ higher RPMS. Also depends on what rocker's he's using. The cam doesn't care how hard those push rods are pushing down on it dude. All it does is spin, that's it.
For what it's worth, I have an e cam in my car, with gt40's and ran a set of springs from Alex Parts, which are good up to .600' worth of lift. I initially put 1.7's on there, (which was .598 worth of lift) but the bolts were bottoming out in the head, so I went back to the 1.6's. They have a better lift and seat pressure capability than the trick flow's. Not only that, but you can't beat the price:
The hex bolts that bolt down the roller rocker to the head would bottom out on the cylinder head. When I torqued the roller rocker hex bolt to 22 ft lbs, I would reach that torque value and there would be a gap under the bolt head, and you could lift the roller rocker up around .060 of an inch. Because I didn't need very many shims under the springs to compensate for the bolt length, so I've got to get shorter bolts. Or just sell the 1.7's all together.
Ok just found out that mine are 1.7s with my gt40 heads so does that mean i will encounter th same problem as you did? And another question is i was told i would have to have something else because i was putting a windsor style head on a 302?
Measure the size of the holes on the new heads, if they are 7/16 they will work perfectly.
If they are 1/2" they will still work fine, just use the little locators Ford uses on the heads from factory.....
