Stroker in a stock block.
Stock 5.0 blocks vary considerably, but 400 hp is roughly seen as the limit for 86-93 blocks (80-85 blocks were weaker) for long life. A mild 331 would probably be okay, a mediocre would be on the bubble, and a racy one would last for a while, but hard to say how long. Main studs and a main girdle is one way to add some strength to the stock block, and many stroked engines add these for increased durability.
80-85 blocks are no weaker than 86-95, early 70's are the tad stronger ones due to thicker main webbing and blind holes in the main studs and 400 hp the limit really?? not even, more like upper 400's, got plenty examples, including my own to dispute that.
Its fairly common knowledge amongst 5.0 builders that the stock fox blocks tend to give out somewhere in the 5-600hp range. We have at least 1 member here who split his block right down the middle of the lifter valley with a stroker/forced induction combo, I believe. At any rate, you'll need to be under the 12sec range at minimum to worry about breaking the block.
Some other factors to consider when building a stroker motor are the balanacing, some stroker kit sellers will want to balance the kits they sell for you. This is a fine idea if you are buying the flexplate/flywheel as well as the harmonic balancer from them, otherwise, getit done locally.
You will also need some aftermarket heads as there are no heads made by Ford that will do the job right and don't even think trying to cheap out by porting any production. Those heads will never keep up.
Stroker motors are not for everyone and they are not 'cheap and easy'.....
