Weird Stuttering
i have a 94 5.0. The engine stutters and bucks unless i REALLY get into the throttle. After it drives for a while, it seems to be less pronounced but still exists. Even with the engine warm, if i restart the car it will do it all over again, even if its already at operating temp. I have replaced:
Fuel Pump
Fuel Filter
ECU
Cap, Rotor
Coil
TPS
MAF
Plugs, Wires
Timing is perfect
i am at a loss -- the computer is a 90. The car had a 5 speed but i swapped in an AOD. Thats the only weird thing. The engine is stock.
any ideas?
Fuel Pump
Fuel Filter
ECU
Cap, Rotor
Coil
TPS
MAF
Plugs, Wires
Timing is perfect
any ideas?
did u change your ecu over to one for a automatic transmission when you did the swap? have you checked your fuel pressure, check the balancer to make shore it hasnt spun could be giving false timing reading
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mungodrums
Sep 28, 2015 10:54 PM
stangin1996gt
Sep 21, 2015 11:01 AM
