1994 mustang GT idle surge
Old 09-21-2012, 12:07 AM
Fstanggt96
Fstanggt96's Avatar
Default 1994 mustang GT idle surge
Just finished putting my brothers engine back together, intake upper/lower, timing, water pump and all accessory drives, radiator, fan etc... Had the timing wrong at first and we think we fixed that, it runs now but has a surging idle, a lifter tick that is slowly waning away. Any ideas? Did a search but didnt find what I was looking for. Gunna run it for a while tomorrow and then drain the oil, check for water/coolant in the oil, then put new oil in cuz the car has been sitting for 6 or 7 years(says the seller) and ill put new gas in it, lol. Also check vacuum lines. Any other ideas????Thanks! - Nathan
Fstanggt96 is offline
Old 09-21-2012, 06:57 AM
djd2392
djd2392's Avatar
Honestly..it's a 5.0... I have an 88lx with a motor with 40,000 miles on it and when its cold or on first start up that car will idle down and sometime stall out after a little bit its fine.. my buddy has had 5 foxes and they all did the same thing.
Then again if its continuing to do it after its been running a bit that may be a different story
djd2392 is offline
Old 09-21-2012, 08:37 AM
Tony71502
Tony71502's Avatar
If it sometimes stall. Something is wrong. They don't produce engines that stall.
Before I rebuilt my engine it had 130k miles on it. NEVER stalled.
Vacuum leak or timing is way off.
Tony71502 is offline
Old 09-21-2012, 11:53 PM
Fstanggt96
Fstanggt96's Avatar
It may be the timing, i agree, haven't messed with it too much, it surges like 800 to 1000 rpm though and after the choke disengages it dies... We seafoamed the gas tank and engine, ran it for about 15 minutes(because we found that after the radiator built up pressure it leaks because of a huge crack, lol) drained the oil(new yesterday, nasty when we drained but no coolant) new oil. Runs and drives, we drove it down the street and back. Good oil pressure... We are cleaning the throttle body and IAC tomorrow to see if that fixs/helps.
Old 09-22-2012, 01:05 PM
Tony71502
Tony71502's Avatar
Choke and throttle body? They don't go on the same application. Choke is for a carb'd car.
Old 09-22-2012, 01:53 PM
dawson1112
dawson1112's Avatar
If its a carb and its hunting a steady Idle ..........Here is the first clue you should look at...........The car has sat for 6 0r 7 years..........
Carbs dont like to sit for along time they get corroded and gummed up. carb thats hunting like that is causes from the float needles sticking or being clogged up .
dawson1112 is offline
Old 09-22-2012, 08:33 PM
BaltRavens
BaltRavens's Avatar
MAF? I had a bad one and my car rough idled and jumped from 800-1300rpms and it would sometimes die.
BaltRavens is offline
Old 09-23-2012, 08:34 AM
dawson1112
dawson1112's Avatar
Lol so after rereading your origanal post I see you said upper/lower intake so that means your fuel injected. The thing that threw me off was you mentioned a choke.
You dont have a choke Idle is controlled by the computer as it gathers data from from a few sensors. The most relevent here is the ect or ( engine coolant temp sensor ) however it also relys on the mas air flow to give it information as to how much air is being pulled in. A surging idle is caused from the maf sensor most likely needing to be cleaned or possably a dirty air filter. If the computer sees a fluctuation in the amount of air being pulled into the throttle body it will try to compensate by slightly adjusting the idle air control causing your idle to fluctuate .
Old 09-23-2012, 11:07 PM
Fstanggt96
Fstanggt96's Avatar
Lol, I figured it wasnt really called a choke, that was just the best way for me to describe it. We repaired the radiator and cleaned the IAC and entire TB, ran it for a while and now it is MUCH better, still has a lifter tick so were going to drive it 1000 miles and change the oil again and jump up a weight. Thanks for the help guys!
Old 09-24-2012, 04:54 AM
dawson1112
dawson1112's Avatar
Have you narrowed down the exact lifter that is making the ticking sound?
I have heard some pretty noisy injectors in my day. It may just be the injectors , or one or two of them clicking open and closed. You may want to think about running some good injector cleaner through the fuel for 3 or 4 tanks especially that it sat for that long. Old fuel in the rail has probly tarnished them all .
Quick Reply: 1994 mustang GT idle surge
