Transmission?
Old Dec 2, 2012 | 12:22 PM
Duncan_GT's Avatar
Duncan_GT
http://www.summitracing.com/parts/fm...r58h/overview/
This is the transmission I was looking at; It says its going to need modified to fit the 94-95 cars. The input shaft is 26 spline, the output shaft is 31 spline. <-- Does this mean I'll need new axles to fit this??
Old Dec 2, 2012 | 01:58 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Originally Posted by Duncan_GT
I meant strength wise. I keep reading they arent as strong as the stock ones
I'm using one, an I'd say my combo was between 450-475 rwhp
Old Dec 2, 2012 | 02:02 PM
mjr46's Avatar
mjr46
no, you'll need a different clutch/disc and maybe yoke...I can't remember what stock spline is on tranny yoke..........and to run the tko on a sn-95, iirc you need to modify crossmember and or a driveshaft spacer, but don't quote me on all of that, research it a little
Old Dec 2, 2012 | 02:06 PM
Duncan_GT's Avatar
Duncan_GT
Yeah I knew about the cross member and lengthening the drive shaft. I've never done any drive line work. Does the output shaft of the trans need to match that of the axles? This is a subject I need to spend some time researching. I did find a RAM clutch to match the TKO
Old Dec 2, 2012 | 02:07 PM
darkmach1's Avatar
darkmach1
Good choice over rebuilding a T5, way better than a t5 as far as strength. No you won't need new axles.
Old Dec 2, 2012 | 02:16 PM
Duncan_GT's Avatar
Duncan_GT
No as in the output shaft spline doesn't need to match the axle splines?
Old Dec 2, 2012 | 02:19 PM
darkmach1's Avatar
darkmach1
The transmission output shaft connects to your driveshaft not to your axles.
Old Dec 2, 2012 | 03:28 PM
Venomantidote95's Avatar
Venomantidote95
Can you recommend a company for the rear end also? Or answer the question of how strong the stock 8.8 is?
Get some superior or moser axles whatever you prefer, and a carrier rebuild kit FMS-M-4700-C GRFRRFRFS is the best stack on the replacement kit.
That should hold what you have....
With the right stuff an 8.8 can be comparable to a 9in! without the weight..
Old Dec 2, 2012 | 03:29 PM
Duncan_GT's Avatar
Duncan_GT
I was thinking everything needed to be the same in terms of spline count
Old Dec 2, 2012 | 03:58 PM
darkmach1's Avatar
darkmach1
Nope.
