Transmission?
Old Dec 1, 2012 | 04:31 PM
Duncan_GT's Avatar
Duncan_GT
Default Transmission?
Is it worth rebuilding (or reinforcing) the T5 in the SN cars or forking out another couple grand for a TKO model? My motor should put low to mid 400's rwhp and I know the stock transmission isn't going to last very long behind it.
Old Dec 1, 2012 | 04:42 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just get a tko, if you get a g-force or a a-5/t-5, it'll all cost you the same in the end
Old Dec 1, 2012 | 08:01 PM
Duncan_GT's Avatar
Duncan_GT
Can you recommend a company for the rear end also? Or answer the question of how strong the stock 8.8 is?
Old Dec 1, 2012 | 10:31 PM
mjr46's Avatar
mjr46
depends on how much power you want to put to it?? I run HD yukon 28 spline axles and at that 4 lug still and my car has run 10.70's on that with 3.73's a rebuilt t-loc and a rear end girdle......so my rear is very mild and it handles the power fine.....an 8.8 is a tough rear, add 31 spline 5 lug axles and either a locker and it'll hold 500 hp.....you could even go c-clip eliminator an take it one step further for added insurance.
Old Dec 1, 2012 | 10:39 PM
Duncan_GT's Avatar
Duncan_GT
The power I'm guessing will be low to mid 400's to the wheels. How much power are you throwing at the rear? I was also going to go the 3.73 route
Old Dec 1, 2012 | 10:47 PM
Duncan_GT's Avatar
Duncan_GT
I'm aiming at an 11 second car but then again I havent even thought about suspension
Old Dec 2, 2012 | 06:41 AM
uedlose's Avatar
uedlose
the 8.8 will take just about anything you can throw at it. but like said it will need better axles and a stock T lock even rebuilt with good clutchs and mods is only marginal at best it works ok for the street and a few times a year at the track but if you are gone to be racing every weekend at the track it will not hold up and it will start breaking clutch's. This why I went with a spool.
Old Dec 2, 2012 | 08:49 AM
Duncan_GT's Avatar
Duncan_GT
Cool, you guys have given me a starting point. On the topic of drive line, are the aluminum driveshafts worth it?
Old Dec 2, 2012 | 10:55 AM
mattdel's Avatar
mattdel
Every penny. Less rotational mass = less power lost.
Old Dec 2, 2012 | 11:08 AM
Duncan_GT's Avatar
Duncan_GT
I meant strength wise. I keep reading they arent as strong as the stock ones
